[osgeo4w-dev] Dependencies for gdal not installed on 64-bit
machines
Charles Karney
charles.karney at sri.com
Tue Sep 20 19:55:54 EDT 2011
How can I get hold of the dependency graph so that I can apply
this manually?
On 09/20/11 17:54, Frank Warmerdam wrote:
> Charles,
> I've seen this from time to time too but it does not seem
> to be specifically due to the 64bitness of the machine.
> I was never able to figure it out though.
> Best regards,
> On Tue, Sep 20, 2011 at 2:49 PM, Charles Karney<charles.karney at sri.com> wrote:
>> I can't get OSGeo4W to work on a 64-bit machine at all. Here are the
>> steps I take
>> Delete existing C:/OSGeo4W
>> Download and run osgeo4w-setup.exe
>> Select express install and uncheck all packages but GDAL
>> Select install
>> Start an OSGeo4W shell
>> Run "gdalinfo"
>> I then get
>> "The application has failed to start because ogdi_32b1.dll was not
>> found."
More information about the osgeo4w-dev
