[osgeo4w-dev] Dependencies for gdal not installed on 64-bit
machines
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Sep 21 14:08:39 EDT 2011
> How can I get hold of the dependency graph so that I can apply
> this manually?
I don't know about a graph, but to build it manually look at setup.ini
(http://download.osgeo.org/osgeo4w/setup.ini) and:
1. search for "@ gdal"
2. note contents of "requires:" line
requires: msvcrt libtiff libjpeg libgeotiff proj hdf5 curl
geos libmysql sqlite3 netcdf libpq expat xerces-c-vc9
hdf4 ogdi gdal15dll
3. repeat loop through each package in the requires list. So far
example "@ libtiff" needs "libjpeg zlib msvcrt libjpeg12", 2 of which
are not mentioned in gdal requires.
I wouldn't do it that way though! Use apt to speed things up:
apt requires gdal
apt requires libtiff
...etc.
Or, all in one line:
for /f %a in ('apt requires gdal') do @apt requires %a>> gdal-requires-list.txt
Sorting and removing dupes is left as an exercise for the reader.
Double the percents to use in a batch file, e.g. %%a.
cheers,
-matt
More information about the osgeo4w-dev
