[osgeo4w-dev] Dependencies for gdal not installed on 64-bit
machines
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Sep 20 20:06:38 EDT 2011
it would be good to identify and fix this sporadic problem. Sometime the
apt command line installer will reveal messages that the regular
installer gobbles up:
See "AptFromScratch" on http://trac.osgeo.org/osgeo4w/wiki/pkg-apt
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 20/09/2011 2:49 PM, Charles Karney wrote:
> I can't get OSGeo4W to work on a 64-bit machine at all. Here are the
> steps I take
> Delete existing C:/OSGeo4W
> Download and run osgeo4w-setup.exe
> Select express install and uncheck all packages but GDAL
> Select install
> Start an OSGeo4W shell
> Run "gdalinfo"
> I then get
> "The application has failed to start because ogdi_32b1.dll was not
> found."
> Other observations:
> * the above steps work OK on a 32-bit machine
> * the installation appeared to install only 2 gdal packages (3 dlls).
> On the 32-bit machine several packages were installed alongside gdal
> (45 dlls).
> It seems that the whole dependency mechanism is non-functional on
> 64-bit machines?
> Any help would be appreciated.
More information about the osgeo4w-dev
