[osgeo4w-dev]
[osgeo4w] #288: GDAL - Datum shift issue (WGS84, NAD27, NAD83)
trac_osgeo4w at osgeo.org
Fri Apr 27 12:41:02 EDT 2012
Reporter: tcgeophysics | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: Datum shift grids NAD27 proj
Hi All,
I am encountering a gdalwarp issue that I have a hard time narrowing
down...
I have a Canadian DEM (CDED) in USGS DEM format in Lat/Lon NAD83 (EPSG
4269) and I want to convert it to an ER Mapper ERS format in UTM Zone 16
NAD27 (EPSG 26716).
The command I use is the following:
> gdalwarp -s_srs EPSG:4269 -t_srs EPSG:26716 -of ERS 042c_0100_deme.dem
042c_0100_deme_NAD27UTMZ16N.ers
And the output is:
> ERROR 1: No such file or directory
> ERROR 1: GDALSuggestedWarpOutput() failed because the passed transformer
failed.
GDAL was installed using osgeo4w.exe installer on my Window 7 machine.
After doing some research it seems that datum shift grids may not be built
by default with Proj.4.
Is there other dependencies that may affect datum shifts?
How can I check that datum shift grids were built and which ones?
What can be an approach to add other datum shift grids?
Thanks
Thomas
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/288>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
