[osgeo4w-dev] #279: Create FileGDB plugin for gdal-19
Jeremy Palmer
JPalmer at linz.govt.nz
Fri Apr 27 15:29:28 EDT 2012
HI Matt,
The FileGDB API, which OGR uses, only supports database version 10.0 and higher.
Jeremy
________________________________________
From: osgeo4w-dev-bounces at lists.osgeo.org [osgeo4w-dev-bounces at lists.osgeo.org] On Behalf Of Matt Wilkie [matt.wilkie at gov.yk.ca]
Sent: Saturday, 28 April 2012 7:21 a.m.
To: osgeo4w-dev
Subject: Re: [osgeo4w-dev] #279: Create FileGDB plugin for gdal-19
(replying to list instead of Trac to turn down the noise)
Thanks for putting this package together!
I get an error using this on our v9.3 geodatabases:
B:\> ogrinfo z:\v4\ENV_1000k.gdb
ERROR 1: Error: Failed to open Geodatabase (This release of the
GeoDatabase is either invalid or out of date.)
It opens a v10 gdb but doesn't list contents:
B:\> ogrinfo z:\v5\ENV_50k.gdb
INFO: Open of `z:\v5\ENV_50k.gdb'
using driver `FileGDB' successful.
I expected something more like the personal-gdb results (though maybe
this an ogrinfo thing and not a file-gdb thing):
B:> ogrinfo z:\Geodatabase\admin1000k.mdb
INFO: Open of `z:\Geodatabase\admin1000k.mdb'
using driver `PGeo' successful.
1: Yukon_poly
2: Outfitting
15: Group_Trapline
16: Game_Management_SubzonesAnno
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
> Reporter: jpalmer | Owner: osgeo4w-dev@…
> Type: task | Status: closed
> Priority: major | Component: Package
> Version: | Resolution: fixed
> Keywords: ESRI FileGDB GDAL |
> Changes (by warmerdam):
> * cc: rburhum (added)
> Comment:
> Done by Ragi (+rburhum).
> Also note I added: [wiki:pkg-gdal-filegdb]
osgeo4w-dev mailing list
osgeo4w-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank You.
More information about the osgeo4w-dev
