[osgeo4w-dev] arcSDE - What do I need to fetch from the arcinfo CDs and where does it go?
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Aug 29 12:31:42 PDT 2012
Hi Phil,
It's been a long time, but I believe all I did last time I needed this
was to copy sde*.dll from the Arcgis bin directory into PATH and then
run ogr2ogr or gdal_translate, get the next DLL name from the error
message and repeat until it worked. In memory I think is worked out to:
/"Necessary components for 9.1 are pe91.dll, sde91.dll and sg91.dll.
Necessary components for 9.2 are pe.dll, sde.dll and sg.dll."/ -- from
http://trac.osgeo.org/fdo/wiki/FdoArcSDE92Notes
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 27-Aug-2012 9:46 PM, Phil Scadden wrote:
> The only help I can find for using SDE with OGR2OGR says you need to
> install the plugin for 9.2 (done) and get the sde client libraries.
> Okay, I have arc CDs. What exactly do I need from the arc CDs and where
> do I copy them to? Its far from clear to me what arcSDE client libraries
> are.
> Thanks.
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120829/aa4629c1/attachment.html>
More information about the osgeo4w-dev
