[osgeo4w-dev] PATH variable issue
klo uo klonuo at gmail.com
Mon Dec 10 07:40:42 PST 2012
Let me introduce myself:
I'm new osgeo4w user, after I discovered gdal and qgis.
I tried it because I started to dislike programs that ship own Python on
board. Believe it or not but I can name more then 5 programs in my current
setup that have own Python distribution aside my system Python distribution
(and it's is a same version!).
Compiling qgis OTOH is not worth to avoid this nuisance, but installing
environment like osgeo4w is what I found excellent choice.
Now, I have one issue with osgeo4w shell - osgeo4w sets it's path as last
item in PATH variable, so if some executable is found in prior set
directories it will be executed instead osgeo4w version, like I just
experienced. Here is how osgeo4w sets path (http://i.imgur.com/AjEJV.png):
[image: Inline image 1]
I opened OSGeo4W.bat to see how it sets variables, and then see it calls
other batch files and all this environment variables setting is
over-complicated I hope for a reason, as it makes user intervention
unlikely. So my suggestion is whatever scripts sets PATH variable to set it
like this:
    set path=%osgeo4w-path%;%path%
instead:
    set path=%path%;%osgeo4w-path%
That way command clashing can be avoided. At least for the issue I had,
when program from my system Python scripts was executed unsuccessfully
instead from osgeo4w Python script folder.
Cheers
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20121210/02f891a7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20121210/02f891a7/attachment-0001.png>
More information about the osgeo4w-dev mailing list
