[osgeo4w-dev] Re: msvcrt v1.0.1-6: please test!
Matt Wilkie maphew at gmail.com
Tue Feb 7 17:29:46 EST 2012
> I hope this is just my system it doesn't like?
FWIW, apt is okay with it:
set osgeo4w_root=d:\sdfs
o:\bin\apt.exe setup
wget http://download.osgeo.org/osgeo4w/setup_test.ini
o:\bin\apt.exe -i etc\setup\setup_test.ini install msvcrt
Since the 7zip tar/bz2 bug has resurfaced I used msys tar to generate the
archive.
I tried starting osgeo-setup.exe from a command shell with a deleted PATH to
try and make sure it wasn't calling msys or other cygwin programs on my
system, without success.
View this message in context: http://osgeo-org.1560.n6.nabble.com/msvcrt-v1-0-1-6-please-test-tp4374307p4374334.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev mailing list
