[osgeo4w-dev] Re: python packages
John Callahan
john.callahan at udel.edu
Thu May 10 15:35:10 EDT 2012
I answered my own question. To see a list of installed modules...
1) install pip
2) run "pip freeze"
Works great. Also works great for installing external packages (as
described on the OSGeo4W wiki.)
- John
On Tue, May 8, 2012 at 2:30 PM, John Callahan <john.callahan at udel.edu>wrote:
> Sorry if this question is trivial.... How do I view a list of the python
> 2.7 packages installed with OSGeo4W? To install/remove packages, I read
> that using pip should work. (
> http://trac.osgeo.org/osgeo4w/wiki/ExternalPythonPackages) Is that still
> the primary method or can pythonwin be used?
> Thanks for your help.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120510/21403b62/attachment.html
More information about the osgeo4w-dev
