[osgeo4w-dev] [osgeo4w] #290: Missing files
trac_osgeo4w at osgeo.org
Sat May 12 21:41:59 EDT 2012
#290: Missing files
Reporter: edi151 | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: missing files
Please see attached prt scrns showing why OSGeo4W won't load.
[[Image()]]Not clear to me how to attach anything yet box below indicates
you can attach things?
'''2 problems''':
1. Command line Error message says it can't load
DLL:C:\OSGeo4W\bin\gdalplugins\gdal_SDE.dll because it couldn't be found
2. When I try to set GDAL/Configuration in IDRISI GDAL Module it says no
"gdal_17.dll file". Have downloaded and installed twice and same result.
Windows Explorer search confirms there is no gdal_17.dll file.
Your help and advice on how to correct these 2 problems would be much
appreciated.
Sincerely,
edi151
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/290>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
