[osgeo4w-dev] liblas installs to python25
Matt Wilkie matt.wilkie at gov.yk.ca
Fri May 25 12:46:01 EDT 2012
Hi Steven,
Judging from the package archives and
http://trac.osgeo.org/osgeo4w/wiki/RequiresPython this has been the case
for some time. I created a new package with the simple change you
mention, but don't know if that is enough as I don't use liblas and
can't test it.
Thanks for the report.
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 22-May-2012 10:46 AM, Steven AuCoin wrote:
> Hello,
> I seem to have a two problems with an easy solution, but was hoping
> someone could point to where I went wrong.
> I have not used the dev version of liblas for python for over a month
> now, and I have come to find that it will not import correctly today.
> The problem was solved by placing the liblas sitepackage into the
> python27 sitepackages folder. i found it in python25 folder. has it
> always installed itself there? or is this a problem with a recent update?
> Does this problem happen for anyone else?
> sa
More information about the osgeo4w-dev mailing list
