[osgeo4w-dev] liblas installs to python25
    Steven AuCoin
    aucoinsj at gmail.com
    Fri May 25 13:33:33 EDT 2012
Thanks for fixing that,
I had to reread the ticked a few times before I realized it was my problem.
Also, I don't know if it helps, but i have used most all attributes and
functions from liblas.color, .file, .header, and just a single test of
.srs. They all seem to work fine from the python27 folder.
Sorry, but I don't know of a way to test the whole systematically,
Thanks again,
sa
On Fri, May 25, 2012 at 1:46 PM, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Hi Steven,
> Judging from the package archives and http://trac.osgeo.org/osgeo4w/**
> wiki/RequiresPython <http://trac.osgeo.org/osgeo4w/wiki/RequiresPython>this has been the case for some time. I created a new package with the
> simple change you mention, but don't know if that is enough as I don't use
> liblas and can't test it.
> Thanks for the report.
> cheers,
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.**yk.ca/geomatics/<http://environmentyukon.gov.yk.ca/geomatics/>
> On 22-May-2012 10:46 AM, Steven AuCoin wrote:
>> Hello,
>> I seem to have a two problems with an easy solution, but was hoping
>> someone could point to where I went wrong.
>> I have not used the dev version of liblas for python for over a month
>> now, and I have come to find that it will not import correctly today.
>> The problem was solved by placing the liblas sitepackage into the
>> python27 sitepackages folder. i found it in python25 folder. has it always
>> installed itself there? or is this a problem with a recent update?
>> Does this problem happen for anyone else?
>> sa
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120525/bcb8a45f/attachment.html
More information about the osgeo4w-dev
