[osgeo4w-dev] [osgeo4w] #311: Setup fails to build
trac_osgeo4w at osgeo.org
Sun Oct 14 21:06:11 PDT 2012
Reporter: lpinner | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords:
As a workaround to #304 (http://trac.osgeo.org/osgeo4w/ticket/304) I’m
trying to build the OSGeo4W installer with a modified manifest
(<requestedExecutionLevel level="asInvoker"). I’ve followed the
instructions in http://trac.osgeo.org/osgeo4w/wiki/SetupDevelopment and
tried to build with an unmodified svn checkout of the setup source and a
completely fresh cygwin with all toolchain requirements installed but I
fall at the first hurdle:
$ pwd
/cygdrive/C/OSGeo4W/setup
$ ./bootstrap.sh
Running bootstrap.sh in libgetopt++
autoheader-2.68: error: AC_CONFIG_HEADERS not found in
configure.in
autoheader failed
Autotool bootstrapping failed. You will need to investigate and
correct
before you can develop on this source tree
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/311>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
