[osgeo4w-dev] [osgeo4w] #311: Setup fails to build
OSGeo4W trac_osgeo4w at osgeo.org
Sun Oct 14 21:08:55 PDT 2012
Reporter:  lpinner  |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  major    |   Component:  Installer
 Version:           |    Keywords:
Comment(by lpinner):
 Sorry, didn't format output as as code block:
 $ pwd
 /cygdrive/C/OSGeo4W/setup
 $ ./bootstrap.sh
 Running bootstrap.sh in libgetopt++
 autoheader-2.68: error: AC_CONFIG_HEADERS not found in configure.in
 autoheader failed
 Autotool bootstrapping failed. You will need to investigate and correct
 before you can develop on this source tree
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/311#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
