[osgeo4w-dev] [osgeo4w] #305: sqlite/spatialite: "sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll"
trac_osgeo4w at osgeo.org
Sat Oct 27 12:18:49 PDT 2012
"sqlite3.dll"
Reporter: hellik | Owner: brushtyler
Type: defect | Status: new
Priority: critical | Component: Package
Version: 1.0 | Keywords: sqlite,spatialite
Comment(by hellik):
Replying to [comment:9 brushtyler]:
> I've built the sqlite3.dll using mingw by {{{ ./configure
SQLITE_ENABLE_RTREE=1 --build=mingw32 --target=mingw32 }}} (though the
nmake.opt file I used the last time set SQLITE_ENABLE_RTREE=1 as well),
> but running grass7-dev after copying the DLL in OSGeo4W/bin it still
raises the error.
> In the traceback I see that grass7 uses python ctypes to load the DLL,
so I tried to do the same from OSGeo4W shell and using python ctypes I can
find the function within the DLL and load it.
> So, are you sure the problem is not within the grass7 code?
thanks for your effort!
but shouldn't it be the other way around, suggested by Sandro (see
https://trac.osgeo.org/osgeo4w/ticket/305#comment:5):
(disable/no SQLITE_ENABLE_RTREE in sqlite) and disable
DISABLE_GEOMETRY_CALLBACKS in spatialite?
Helmut
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/305#comment:11>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
