[osgeo4w-dev] [osgeo4w] #301: Problem running gdal*.py in osgeo4w shell
trac_osgeo4w at osgeo.org
Mon Sep 10 03:24:13 PDT 2012
Reporter: vascobnunes | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: osgeo4w, gdal
I'm trying to run gdal_calc.py (and other gdal*.py) from the Osgeo4w shell
and can't do it cause I get this error:
C:\>gdal_calc
File "C:\OSGeo4W\\bin\gdal_calc.py", line 47, in <module>
import gdal
File "C:\OSGeo4W\apps\Python27\lib\site-packages\gdal.py", line 2, in
<module>
from osgeo.gdal import deprecation_warn
File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py",
line 21,
in <module>
_gdal = swig_import_helper()
line 17,
in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: The specified procedure could not be found.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/301>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
