[osgeo4w-dev] [osgeo4w] #301: Problem running gdal*.py in osgeo4w shell
trac_osgeo4w at osgeo.org
Tue Sep 11 10:48:35 PDT 2012
Reporter: vascobnunes | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: osgeo4w, gdal
Old description:
> I'm trying to run gdal_calc.py (and other gdal*.py) from the Osgeo4w
> shell and can't do it cause I get this error:
> C:\>gdal_calc
> Traceback (most recent call last):
> File "C:\OSGeo4W\\bin\gdal_calc.py", line 47, in <module>
> import gdal
> File "C:\OSGeo4W\apps\Python27\lib\site-packages\gdal.py", line 2, in
> <module>
> from osgeo.gdal import deprecation_warn
> File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py",
> line 21,
> in <module>
> _gdal = swig_import_helper()
> line 17,
> in swig_import_helper
> _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: DLL load failed: The specified procedure could not be found.
New description:
I'm trying to run gdal_calc.py (and other gdal*.py) from the Osgeo4w shell
C:\>gdal_calc
import gdal
<module>
line 21,
in <module>
line 17,
Comment(by maphew):
It works for me at present. Perhaps your PATH environment isn't completely
set, or there is something in it that shouldn't be (?)
From a fresh install of nothing but `gdal-python` and prerequisites,
'''Start > Run > cmd''' then:
c:\>path=%windir%;%windir%\system32
c:\>c:\osgeo4w\OSGeo4W.bat
OSGEO4W home is c:\osgeo4w\
-={ OSGeo4W Shell Commands }=-
---8<---snip---
GDAL 1.9.1, released 2012/05/16
c:\>gdal_calc
gdal_calc.py [-A <filename>] [--A_band] [-B...-Z filename] [--calc
<calculation>]
[--format] [--outfile output_file] [--type data_type] [--NoDataValue]
[--overwrite]
c:\>
host system is Win7 Pro x64.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/301#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
