[osgeo4w-dev] grid statistiscs by polygon using OsGeo4W
Siebe Bosch siebe at hydroconsult.nl
Thu Apr 4 00:41:07 PDT 2013
Dear list,
Not sure whether this is the right place to ask this question, but I've
been busy for quite some time trying to figure out the following:
  * I have a large number of NetCDF-files (one file for each day and
    each file containing 24 data bands = hours)
  * I have a shapefile with polygons
Now for each polygon in the shapefile I need to create a time series
with values from NetCDF.
This means that for every timestep I will have to extract the average
value from the NetCDF within each polygon.
 1. Is there a way I can do this from the command line or a DLL using
    OSGEO4W?
 2. How fast is the routine? I will have to process e.g. 365 * 10
    netCDF-files
Thanks in advance for your response.
Kind regards,
Siebe Bosch
Hydroconsult
Lulofsstraat 55, unit 47
2521 AL Den Haag
The Netherlands
web: http://www.hydroconsult.nl
e-mail: siebe at hydroconsult.nl
phone: +31(0)70 250 0580
mobile: +31(0)6 17 682 689
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130404/4e26447e/attachment.html>
More information about the osgeo4w-dev mailing list
