[osgeo4w-dev] ANN: Python 2.7.4
    jamesstott
    jamesstott at hotmail.com
    Wed Apr 24 03:21:09 PDT 2013
Thanks for the reply.
Its there for ArcGIS yes (in the syswow64 folder) so I cannot remove or
rename it permanently.
Renaming it does make QGIS 1.8 open again. QGIS master is fine in either
case.
Is there a longer term solution to this as I dont want to keep renaming a
DLL each time I want to load ArcGIS/QGIS? It all worked fine until
yesterday.
Also, renaming the dll doesn't fix the error when running of a python script
at the OSGeo4W command line.
James
View this message in context: http://osgeo-org.1560.x6.nabble.com/ANN-Python-2-7-4-tp5048404p5049326.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev
