[osgeo4w-dev] ANN: Python 2.7.4
Jürgen E. Fischer jef at norbit.de
Wed Apr 24 14:14:57 PDT 2013
Hi Matt,
On Wed, 24. Apr 2013 at 10:55:06 -0700, Matt Wilkie wrote:
> If that's not possible you'll need to modify your o4w startup scripts to
> strip the Windows system directories from PATH, which may break other
> things.
As said, that doesn't work:  system32 takes precedence over PATH.  The only
option left I know is to put the DLL into the same directory that the
executable that loads the DLL.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
