[osgeo4w-dev] [osgeo4w] #358: Cannot start QGIS from OSGeo4W terminal - qgis_core.dll is missing
OSGeo4W trac_osgeo4w at osgeo.org
Thu Apr 25 15:34:39 PDT 2013
Reporter:  saultdon  |        Owner:  osgeo4w-dev@…
    Type:  defect    |       Status:  closed
Priority:  minor     |    Component:  Package
 Version:            |   Resolution:  fixed
Keywords:            |
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 putting the stuff into etc/ini won't work as the settings for different
 qgis version would conflict - that's why the batch files are there.
 That it changed is because qgis.exe was moved to the main bin, because
 that makes it use DLLs existing there even if a different version exists
 in system32 (ie. python27).
 And now qgis.exe and qgis.bat both live in the same directory.
 A note in [[wiki:pkg-qgis]] was added.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/358#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
