[osgeo4w-dev] [osgeo4w] #364: matplotlib: split tests and mpl-data into separate package matplotlib-tests
OSGeo4W trac_osgeo4w at osgeo.org
Mon Aug 26 03:03:40 PDT 2013
Reporter:  martinl     |        Owner:  osgeo4w-dev@…
    Type:  defect      |       Status:  closed
Priority:  major       |    Component:  Package
 Version:              |   Resolution:  fixed
Keywords:  matplotlib  |
Comment(by martinl):
 Replying to [comment:2 alexbruy]:
 > Sorry for delay, was busy with two parallel projects at work.
 > Testing stuff removed from matplotlib package and now its size is about
 5 Mb. mpl-data subdirectory still included because it contains required
 files and should be installed anyway.
 Thanks a lot! Martin
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/364#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
