[osgeo4w-dev] Python in OSGeo4W
Paolo Corti
pcorti at gmail.com
Wed Dec 4 01:29:15 PST 2013
Hi
On Tue, Dec 3, 2013 at 7:59 PM, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Hi Paolo,
> Osgeo4w Python doesn't register itself with Windows. So it's likely that o4w
> python is there, just not visible. It should be located at
> C:\Osgeo4w\apps\python27. To test for it, open "Osgeo4W Shell" and run
> "python --version".
If you run the OSGeo shell, Python will work without having to set the
path, and this is not the case in the system experiencing the problem
in the subject.
As written in my previous email, Python and all the other
stuff were not installed at all by the OSGeo4W installer, and I do not
understand why, therefore I decided to send this email to the list.
After running the installer, there is not C:\Osgeo4w\apps\python27,
but apps contains just a msvcrt directory with a single file inside
it.
If I try the advanced installation, all the Python libraries are
marked as "Not Available".
regards
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the osgeo4w-dev
