[osgeo4w-dev] Python in OSGeo4W
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Dec 3 10:59:40 PST 2013
Hi Paolo,
Osgeo4w Python doesn't register itself with Windows. So it's likely that
o4w python is there, just not visible. It should be located at
C:\Osgeo4w\apps\python27. To test for it, open "Osgeo4W Shell" and run
"python --version".
ArcGIS python and Osgeo4W python are not guaranteed to be so. The ArcGIS
py lives at C:\Python27\ArcGIS10.x. Having both of them in PATH at once
/will /lead to problems sooner or later, though depending on what
modules are used it's possible to trundle along happily for quite awhile.
There's instructions for getting ArcGIS 9.x to use o4w python instead of
it's own at
http://gis.stackexchange.com/questions/134/can-arcgis-and-osgeo4w-share-the-same-python-install,
which I used successfully for many years. I haven't tried that since we
migrated to 10.x though and am maintaining 3 distinct pythons (Arc, o4w,
python3).
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 03/12/2013 5:02 AM, Paolo Corti wrote:
> Hello list
> I am not a Windows user, but the few times I have been using OSGeo4W
> it was working like a charm, so the following problems sounds strange
> to me.
> A colleague of mine is trying to install it on his Windows 7 64 bit
> box, and for some reason the installer does not install Python and all
> the Python stuff at all (Python GDAL bindings and so on).
> Not sure if this could be related: on this system there is already
> another Python (2.7) that was installed together with the ArcPy ArcGIS
> Desktop library, but it is not set on PATH.
> Any hints of what it could be?
> thanks in advance
> p
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20131203/1fbebc1e/attachment.html>
More information about the osgeo4w-dev
