[osgeo4w-dev] Binary inconpatible GDAL plugin for Oracle
Ivan Lucena
ivan.lucena at princeton-ma.us
Wed Feb 27 10:49:30 PST 2013
Hi Jürgen,
I am not a OSGeo4w contributor, so I don't know how things are build. But I remember that at one time, probably 4 years ago, I uploaded the Oracle plugins to GDAL ftp repository (That doesn't exist anymore) and those DLL where used by OSGeo4W, some how, without my acknowledge. That is to me a hint that indicates that the plugins are not build on the same environment as the GDAL tools are.
Anyway, here comes the symptoms:
1 - After installing GDAL latest (1.9.2) with GDAL-Oracle plugins, the OSGeo4W show an error message when it tries to run "gdalinfo --version" at the end of the shell initialization script.
2 - Running gdalinfo or ogrinfo with Oracle driver doesn't work and the errors random, sometimes an error message pops up, sometimes nothing happens, just the prompt comes back without any printing.
3 - QGIS also doesn't work when you try to load vector or raster. You might get a connection sometimes or even get a georaster to display but it crashes when loading geometries.
4 - Everything goes back to normal if I Just do that:
C:\OSGeo4W\bin\gdalplugins\1.9> copy "\Program Files (x86)\GDAL\gdalplugins\gdal_GEOR.dll" .
C:\OSGeo4W\bin\gdalplugins\1.9> copy "\Program Files (x86)\GDAL\gdalplugins\ogr_OCI.dll" .
5 - On that source folder I have GDAL installed from gdal-19-1600.core.msi and gdal-19-1600-oracle.msi. I tried with gdal-19-1500-core.msi and gdal-19-1500-core.msi and got similar problems as with the original OSGeo4W GDAL Oracle plugins.
So it seems like the problem is about VC binary incompatibility. IMHO.
But I understand you point, the problem deserves a good explanation.
One more think. I have users that got QGIS directly from QGIS website and encountered the same problem after installing and trying to use the Oracle plugins. Would that be a coincidence?
If some that knows the building/assembling and installation process in OSgeo4W could help. That would be great.
Best regards,
Ivan
> -------Original Message-------
> From: Jürgen E. Fischer <jef at norbit.de>
> To: osgeo4w-dev at lists.osgeo.org
> Subject: Re: [osgeo4w-dev] Binary inconpatible GDAL plugin for Oracle
> Sent: Feb 27 '13 12:33
> Hi Ivan,
> On Wed, 27. Feb 2013 at 12:11:53 -0500, Ivan Lucena wrote:
> > After updating to the latest distribution of GDAL command line and QGIS from
> > OSGeo4W users are having problem when the application tries to load the GDAL
> > plugins related to Oracle.
> > I tried to replace the plugins libraries ogr_OCI.dll and gdal_GEOR.dll with
> > the ones provided by www.gisinternals.com/sdk and it seems like the correct
> > version would be GDAL 1.9.2 compiled with MSVC 2010, that is VC 1600. That
> > works for GDAL command line and QGIS.
> Why should those be any better than what it shipped in OSGeo4W already? The
> gdal oracle plugin are built with OCI package in OSGeo4W against the GDAL in
> OSGeo4W.
> > Should I file a ticket for that?
> If it clearer than the description above - doesn't tell much about how to
> reproduce the problem.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> osgeo4w-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
