[osgeo4w-dev] mapscript.py problem for qgis-dev
Mon Jun 17 11:25:27 PDT 2013
Luigi,
Are you intentionally doing this with mapserver-dev and it's
mapscript-python as opposed to the new mapscript-python package I prepared
for MapServer 6.2 for you folks?  You may need to explicitly uninstall that
old mapscript-python and mapserver-dev (which is now quite ancient).
Best regards,
Frank
On Mon, Jun 17, 2013 at 10:43 AM, Gino Pirelli <luipir at gmail.com> wrote:
> Hi, I'm Luigi Pirelli working for Faunalia.it (luigi.pirelli at faunalia.it)
> execution a qgis-dev python plugin, I can't load mapscript.py module
> due to lack fo DLLs. The problem is knows since 5 years:
>    http://trac.osgeo.org/osgeo4w/ticket/26
> so, I think that a problem related to an old win version...
> Please let me know if there is a solution. Here is the log ot the tests I
> did:
> Changed 51 minutes ago by luigi.pirelli@…
> First test with a clean QGIS master and mapscript OSGeo4W on a WinXP
> Pro SP3 virtual machine.
> Mapscript is mapscript-dev-python (5.2b3-1) installed in:
> C:\OSGeo4W\apps\mapserver-dev\mapscript-python
> Running plugin generate this error:
> File "C:/OSGeo4W/apps/qgis-dev/./python\qgis\utils.py", line 454, in
> _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> ImportError?: DLL load failed: The specified module could not be found.
> Running Dependency Walker on _mapscript.pyd show the need of these
> packages:
> LIBMAP_DEV.DLL and PYTHON25.DLL
> it's a OSGeo4W installer bug?
> __________________________
> comment:3 in reply to: ↑ 2Changed 15 minutes ago by luigi.pirelli@…
> the same happend installing:
> mapscript-python (5.0.2-1)
> that is installed in: C:\OSGeo4W\apps\Python25\lib\site-packages
> Running Dependency Walker results the same missing libraries
> comment:4Changed 0 seconds ago by luigi.pirelli@…
> TEST on: http://home.gdal.org/tmp/mapscript-python-6.2.1-2.tar.bz2
> after cleaning of all mapscript available in C:\OSGeo4W I uncompressed
> it (so installed mapscritp.py in
> C:\OSGeo4W\apps\python27\lib\site-packages)
> but obtained another error:
> File "C:\OSGeo4W\apps\Python27\lib\site-packages\mapscript.py", line 23, in
> swig_import_helper
> return _mod UnboundLocalError?: local variable '_mod' referenced
> before assignment
> so... no mapscript available seems to work with qgis-dev
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130617/3eb9036e/attachment.html>
More information about the osgeo4w-dev mailing list
