[osgeo4w-dev] [osgeo4w] #389: Matplotlib issue causing crash in ProfileTool plugin. "UnicodeDecodeError?: 'ascii' codec can't decode byte 0x8e in position 8: ordinal not in range(128) "
trac_osgeo4w at osgeo.org
Mon Nov 4 23:50:43 PST 2013
range(128) "
Reporter: nicolascadieux | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: matplotlib, x86_64
Changes (by alexbruy):
* keywords: Matplotlib => matplotlib, x86_64
Comment:
This only happens if 64-bit build used, 32-bit builds (standalone QGIS and
OSGeo4W) works fine.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/389#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
