[osgeo4w-dev] [osgeo4w] #389: Matplotlib issue causing crash in ProfileTool plugin. "UnicodeDecodeError?: 'ascii' codec can't decode byte 0x8e in position 8: ordinal not in range(128) "
trac_osgeo4w at osgeo.org
Tue Nov 5 00:04:51 PST 2013
range(128) "
Reporter: nicolascadieux | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: matplotlib, x86_64
Comment(by alexbruy):
Just tested on two other computers with clean 64-bit Windows 7 install and
64-bit OSGeo4W installer. There is no error. Maybe this is depends on some
environment settings
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/389#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
