[osgeo4w-dev] OSGeo4W setup no longer works (setup.ini is empty)
andreaerdna andreaerdna at libero.it
Mon Oct 7 06:10:25 PDT 2013
It seems that setup.ini (and also setup.ini.bz2, setup.ini.prev,
setup_test.ini, setup_test.ini.prev) at http://download.osgeo.org/osgeo4w/
is empty so OSGeo4W setup no longer works as it should.
Does anybody know why it happened and how to solve the problem?
Andrea
View this message in context: http://osgeo-org.1560.x6.nabble.com/OSGeo4W-setup-no-longer-works-setup-ini-is-empty-tp5082195.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev mailing list
