[osgeo4w-dev] QGIS and GRASS packages displayed twice
Alex Mandel
tech_dev at wildintellect.com
Fri Sep 13 13:14:34 PDT 2013
On 09/13/2013 01:08 PM, Vaclav Petras wrote:
> Hi all,
> yesterday I noticed that QGIS and GRASS packages displayed twice in the
> package list in the advanced section using the standard 32bit installer.
> Each package has slightly different version number. Is this some
> translation package problem or is it a bug?
> I've also some unrelated problem, some German language message (using
> English locale) popped up during installation saying something about non
> enough space on disk (although I have) and it seemed to be related to MS
> dlls. I think that this can be related to 'Run as admin/Install for all'
> problem but I'm not sure about the combination I tried that time and I
> don't have screenshot either. So, I'm not sure if you can help me also with
> this.
> Vaclav
Which versions did you see listed? Normally for QGIS there is the stable
release,1.8 and the development version 1.9 (or other names).
You might also being seeing the 2.0 package working in as that is
currently in the process of being prepared for release.
Thanks,
Alex
More information about the osgeo4w-dev
