[osgeo4w-dev] QGIS and GRASS packages displayed twice
Vaclav Petras wenzeslaus at gmail.com
Fri Sep 13 15:04:21 PDT 2013
On Fri, Sep 13, 2013 at 4:14 PM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
> On 09/13/2013 01:08 PM, Vaclav Petras wrote:
> > Hi all,
> > yesterday I noticed that QGIS and GRASS packages displayed twice in the
> > package list in the advanced section using the standard 32bit installer.
> > Each package has slightly different version number. Is this some
> > translation package problem or is it a bug?
> > I've also some unrelated problem, some German language message (using
> > English locale) popped up during installation saying something about non
> > enough space on disk (although I have) and it seemed to be related to MS
> > dlls. I think that this can be related to 'Run as admin/Install for all'
> > problem but I'm not sure about the combination I tried that time and I
> > don't have screenshot either. So, I'm not sure if you can help me also
with
> > this.
> > Vaclav
> Which versions did you see listed? Normally for QGIS there is the stable
> release,1.8 and the development version 1.9 (or other names).
I'm not sure about QGIS, for GRASS there were certainly only different
revisions.
> You might also being seeing the 2.0 package working in as that is
> currently in the process of being prepared for release.
> Thanks,
> Alex
On Fri, Sep 13, 2013 at 4:16 PM, Lord Flaubert Steve Ataucuri Cruz <
lord.ataucuri at ucsp.edu.pe> wrote:
> We added a new translation of German Language , I want to see more about
the message error and try to fix.
> Steve
I will remember to take screen shots of both errors next time!
Thank you anyway,
Vaclav
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130913/5dec454d/attachment.html>
More information about the osgeo4w-dev mailing list
