[osgeo4w-dev] [osgeo4w] #376: GDAL returns incorrect NoData Value for PostGIS raster
    trac_osgeo4w at osgeo.org
    Fri Sep 20 14:57:42 PDT 2013
Reporter:  mlt     |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:  gdal,postgis
Comment(by mlt):
 OS is MS Windows XP 32 bit SP3[[br]]
 select version() returns "PostgreSQL 9.2.4, compiled by Visual C++ build
 1600, 32-bit"[[br]]
 select postgis_full_version() returns "POSTGIS="2.0.3 r11132"
 GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2,
 released 2012/10/08" LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER"
 gdalinfo 1.10 from
 http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1500-gdal-1-10-0-mapserver-6-2-1.zip
 returns correct NoData Value=9999.
 I suggest to update bundled GDAL if it does not break anything else.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/376#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
