[osgeo4w-dev] offline install
Steve.Toutant at inspq.qc.ca
Thu Feb 27 06:55:17 PST 2014
Hi Jürgen
Thanks for your answer.
Yes I used OSGeo4W 64bit setup.
I have a 64bits Windows OS, will osgeo4w 32bits setup and packages will
work well?
If so why there is a 64bits setup if it is incompete and 32bits can be
used?
Regards
Steve
Jürgen E. Fischer <jef at norbit.de>@lists.osgeo.org
Envoyé par : osgeo4w-dev-bounces at lists.osgeo.org
2014-02-26 17:19
A
osgeo4w-dev at lists.osgeo.org
cc
Objet
Re: [osgeo4w-dev] offline install
Hi Steve,
On Wed, 26. Feb 2014 at 14:15:32 -0500, Steve.Toutant at inspq.qc.ca wrote:
https://trac.osgeo.org/osgeo4w/wiki/FAQ#HowdoIperformanofflineorcomputerlabinstall
> But Apache is not in the list
> And I see mapserver but not phpmapscript
I suppose you're trying to install OSGeo4W 64bit. The 64bit build
contains
less packages than the 32bit version. It doesn't have apache and
phpmapscript
for instance.
See http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html for a
comparison.
So you probably want to use OSGeo4W 32bit.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel.
+49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax.
+49-4931-918175-50
Software Engineer D-26506 Norden
http://www.norbit.de
QGIS PSC member (RM) Germany IRC: jef on
FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
osgeo4w-dev mailing list
http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20140227/5ba3472d/attachment.html>
More information about the osgeo4w-dev
