[osgeo4w-dev] offline install
Jürgen E. Fischer jef at norbit.de
Wed Feb 26 14:19:04 PST 2014
Hi Steve,
On Wed, 26. Feb 2014 at 14:15:32 -0500, Steve.Toutant at inspq.qc.ca wrote:
> https://trac.osgeo.org/osgeo4w/wiki/FAQ#HowdoIperformanofflineorcomputerlabinstall
> But Apache is not in the list
> And I see mapserver but not phpmapscript
I suppose you're trying to install OSGeo4W 64bit.   The 64bit build contains
less packages than the 32bit version.  It doesn't have apache and phpmapscript
for instance.
See http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html for a
comparison.
So you probably want to use OSGeo4W 32bit.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
