[osgeo4w-dev] [osgeo4w] #400: SAGA downgrades to 2.0.8 by default when installing or modifying installed packages
OSGeo4W trac_osgeo4w at osgeo.org
Thu Jan 9 08:54:13 PST 2014
packages
Reporter:  saultdon  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  major     |   Component:  Installer
 Version:            |    Keywords:
 If you install SAGA GIS 2.1.0 it works.
 But if you go back into setup later on and do anything, when you hit next
 the installer always switches SAGA to 2.0.8 and installs that version.
 You have to always make sure that you change SAGA back to v2.1.0 so that
 it isn't downgraded.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/400>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
