[osgeo4w-dev] New package for Mapserver 6.4
Jerome Villeneuve Larouche
jlarouche at mapgears.com
Thu Jan 9 06:52:33 PST 2014
Well, Python-Mapscript is for 6.2 only so with 6.4.1 in the Mapserver
directory it only replaces 5.2. You can still install Mapserver 6.2 from
Mapserver6 and then Python-Mapscript. For the setup.hint file, I only
need to add libfreetype to the current one and it'll work.
So I think that leaving mapserver 6.4.1 in the Mapserver directory would
be best.
On 14-01-08 05:00 PM, Jürgen E. Fischer wrote:
> Hi Jérôme,
> On Wed, 08. Jan 2014 at 13:10:26 -0500, Jerome Villeneuve Larouche wrote:
>> I put the package in the mapserver folder without a setup.hint if you
>> want to review it. I haven't regen.sh or promote_test.sh, should I run
>> it now even with no setup.hint?
> That directory already has a setup.hint, so if you run the scripts (but please
> not directly, but through the CGIs), it will already be already included. That
> also will happen around 16:00 -0800 (QGIS nightly build; ie. about 2h away).
> I must admit that I'm not familiar with the mapserver packages in osgeo4w.
> The new mapserver 6.4 package should probably be in mapserver6 and replace the
> 6.2.0 package. But in the current stage that would probably break the
> existing mapscript-python package, which is not what we want.
> If we leave it like it is for now, it will replace mapserver 5.2.2, which
> conflicts with the other mapservers and in turn python mapscript. I don't
> know if anybody is still using 5.2. I would expect it to be harmless, but
> there were about 72 downloads in last three days...
> If it's going to replace the current mapserver6 package, there also should be a
> new mapscript-python package.
> And having all that for 64bit would certainly fill a big empty spot in the
> 64bit repository - especially when it comes with python mapscript - which I
> know is sorely missed by some QGIS users. I also know that Tamas intended to
> add python mapscript to the 64bit build - but I don't know anything about the
> timeframe. Also note that osgeo4w 64bit doesn't have apache (not even the
> ancient version 32bit has).
> Jürgen
Jérôme Villeneuve Larouche
www.mapgears.com
More information about the osgeo4w-dev
