[osgeo4w-dev] OSGeo4W-64bit: qgis 2.4 - GRASS raster can't be loaded
Helmut Kudrnovsky
hellik at web.de
Sun Jul 6 11:33:20 PDT 2014
>> warning: projection can't be determined
>> modul can't be executed
>> command C:/OSGEO~1/apps/qgis/./grass/modules/qgis.g.info info=proj
>> <br><br>
>> any idea?
>Not really. I can open the gtopo30 map from the qgis_sample_data set just
>fine.
ok, it seems the underlying problem is in a broken OSGeo4W-GRASS6.4.3-5
64bit.
I can start a GRASS session only in text mode because g.proj (and some other
modules, e.g. g.region, g.setproj) seems to be broken in
OSGeo4W-GRASS6.4.3-5 64 bit.
in a GRASS session in text mode I can start the module GUI e.g. by
GRASS 6.4.3 (nc_spm_08)> g.mlist --ui
or get the manual by
GRASS 6.4.3 (nc_spm_08)> g.mlist --help
Beschreibung:
Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten
Datentyps
und verwende optional ein Suchmuster.
Schlüsselwörter:
Allgemein, Kartenverwaltung
but I can not do this for g.proj, g.region, g.setproj; therefore the QGIS
error:
>> <br><br>
as the underlying GRASS module isn't working correctly.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/OSGeo4W-64bit-qgis-2-4-GRASS-raster-can-t-be-loaded-tp5149806p5149858.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev
