[osgeo4w-dev] where does osgeo4w-setup keep the state of installed/uninstalled apps?
G. Allegri
giohappy at gmail.com
Mon May 19 14:15:17 PDT 2014
Thanks Jurgen.
I ddidn't write down what was remaining. I only remember a couple of
folders under Osgeo4w/apps/qgis. I will reproduce the process on another
pc in the next days, then I will report it.
giovanni
2014-05-19 20:21 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Giovanni,
> On Mon, 19. May 2014 at 14:44:32 +0200, G. Allegri wrote:
> > I need to completely uninstall QGIS from a machine. Having had problems
> > with the removal from osgeo4w-setup (a lot of stuff remaining around),
> And what remained?
> > and finally I thought I should have removed the lines from
> osgeo4w-setup's
> > setup.ini.
> setup.ini lists the available packages.
> > Running osgeo4w-setup.exe I was surprised to see QGIS still flagged as
> > installed. Where does osgeo4w-setup keep the state of
> > applications?
> The installed packages are in etc/setup/installed.db.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM) Germany IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20140519/4cd21fcc/attachment.html>
More information about the osgeo4w-dev
