[osgeo4w-dev] where does osgeo4w-setup keep the state of installed/uninstalled apps?
Jürgen E. Fischer jef at norbit.de
Mon May 19 11:21:29 PDT 2014
Hi Giovanni,
On Mon, 19. May 2014 at 14:44:32 +0200, G. Allegri wrote:
> I need to completely uninstall QGIS from a machine. Having had problems
> with the removal from osgeo4w-setup (a lot of stuff remaining around),
And what remained?
> and finally I thought I should have removed the lines from osgeo4w-setup's
> setup.ini.
setup.ini lists the available packages.
> Running osgeo4w-setup.exe I was surprised to see QGIS still flagged as
> installed. Where does osgeo4w-setup keep the state of installed/uninstalled
> applications?
The installed packages are in etc/setup/installed.db.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
