[osgeo4w-dev] Removing Java
andrea antonello
andrea.antonello at gmail.com
Fri Dec 4 10:12:01 PST 2015
Hi Juergen,
> On Fri, 04. Dec 2015 at 12:14:14 +0100, andrea antonello wrote:
>> So if you think that might be a problem for you, speak up (and be the
>> next maintainer :-) ) or be silent forever.
> Which java is gvsig going to use?
I am not sure about it yet, but right now we are tempted to place the
jre inside the gvSIG installation, in order to avoid conflicts and
version problems.
It will sure be a java 7 for this gvSIG version.
If some other project needs java, it should step up and discuss its
needs, so that we can coordinate.
Cheers,
Andrea
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
