[osgeo4w-dev] Removing Java
andrea antonello andrea.antonello at gmail.com
Sun Dec 13 22:49:59 PST 2015
> I'd vote for removing Java now and to re-package it again when needed.
> In this way we can assay a new packaging scheme in the following
> months, avoiding the libxml conflict and offering Java version 8
> instead of 7.
Same here. If no one needs java 7, I would do this version of gvSIG with
java inside. With the next release it should be on java 8 and at that point
it makes sense to merge efforts.
Cheers,
Andrea
> Best regards,
> César
> 2015-12-08 17:20 GMT+01:00 Julien Malik <julien.malik at c-s.fr>:
> > Hi,
> > I would like to, in the mid-term (say in a few months), integrate SNAP
> and
> > the Sentinel Toolboxes [1] in OSGeo4W.
> > Currently we distribute installers with the jre included, but making it
> > available in OSGeo4W is on my todo-list.
> > It would make lots of sense since I've already seen QGIS Processing
> plugins
> > with SNAP as a backend. Also SNAP provides Python bindings, but our
> > installers do not embed any interpreter.
> > It needs Java 8.
> > Cheers,
> > Julien
> > [1] http://step.esa.int/main/
> > On 04/12/2015 19:12, andrea antonello wrote:
> >> Hi Juergen,
> >>> On Fri, 04. Dec 2015 at 12:14:14 +0100, andrea antonello wrote:
> >>>> So if you think that might be a problem for you, speak up (and be the
> >>>> next maintainer :-) ) or be silent forever.
> >>> Which java is gvsig going to use?
> >> I am not sure about it yet, but right now we are tempted to place the
> >> jre inside the gvSIG installation, in order to avoid conflicts and
> >> version problems.
> >> It will sure be a java 7 for this gvSIG version.
> >> If some other project needs java, it should step up and discuss its
> >> needs, so that we can coordinate.
> >> Cheers,
> >> Andrea
> >>> Jürgen
> >>> Jürgen E. Fischer           norBIT GmbH             Tel.
> >>> +49-4931-918175-31
> >>> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> >>> +49-4931-918175-50
> >>> Software Engineer           D-26506 Norden
> >>> http://www.norbit.de
> >>> QGIS release manager (PSC)  Germany                    IRC: jef on
> >>> FreeNode
> >>> _______________________________________________
> >>> osgeo4w-dev mailing list
> >>> osgeo4w-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
> SCOLAB
> http://scolab.es
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20151214/0d9c3211/attachment.html>
More information about the osgeo4w-dev mailing list
