[osgeo4w-dev] using Pyscripter with Osgeo4w
    Matt Wilkie
    maphew at gmail.com
    Sat Mar 21 11:02:20 PDT 2015
Hi Folks,
This took a bit of time to figure out, so I figured out I'd share for
posterity. Pyscripter isn't my normal IDE, but it's popular, especially in
the ArcGIS ecosystem. Here's how to get it working with Osgeo4W python
instead of "the other one":
Install pyscripter, create this batchfile, adjusting path as needded, and
save it in PATH, run it, done.
    %~d0\apps\PyScripter\PyScripter.exe %*
--pythondllpath=%osgeo4w_root%\bin
Explanation:
    %~d0: expands to Drive letter that batch file exists on, e.g.
c:\bin\pyscripter.bat
    %*: expands command line arguments, allows `pyscripter.bat
d:\code\somefile.py`. It *must* precede pyscripter option arguments.
    --pythondllpath: needed when pythonxx.dll doesn't reside in same folder
as python.exe.
cheers,
Matt
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20150321/97b09e56/attachment.html>
More information about the osgeo4w-dev
