[osgeo4w-dev] apt 0.3-1 test release
Matt Wilkie
maphew at gmail.com
Sat May 2 01:33:55 PDT 2015
Hi Folks,
Apt-0.3-3 released tonight as "apt-exe" in package list. It should be
somewhat smarter about removing older versions than 0.3-1. Please let me
know if there are any issues installing or using it. The issue tracker is
at https://github.com/maphew/apt/issues
cheers,
Matt
On Fri, Mar 6, 2015 at 4:58 PM, Matt Wilkie <maphew at gmail.com> wrote:
> Hi Folks,
> I've uploaded a new apt.exe release, so far only in testing.To install or
> upgrade use "setup-test.bat" to use regular installer and/or apt itself.
> For the latter:
> Download test ini:
> wget http://download.osgeo.org/osgeo4w/x86/setup_test.ini
> Run:
> apt -i setup_test.ini new
> ...which should report:
> The following packages are newer than the installed version:
> apt 0.3-1
> Then run:
> apt -i setup_test.ini upgrade
> Which should emit:
> Fetching
> http://download.osgeo.org/osgeo4w/x86/release/apt/apt-0.3-1.tar.bz2
> ...100% D:/xxxxx//var/cache/setup/http%3a%2f%2fdownload.osgeo.org
> %2fosgeo4w/x86/release/apt/apt-0.3-1.tar.bz2
> e6f900c62b4cbee1c4092e1d1d8244d1 apt-0.3-1.tar.bz2 - remote
> e6f900c62b4cbee1c4092e1d1d8244d1 apt-0.3-1.tar.bz2 - local
> preparing to replace apt 0.0-8
> removed: D:\xxxxx\bin\apt.bat
> removed: D:\xxxxx\bin\apt-dev.py
> removed: D:\xxxxx\bin\apt-r1193M.exe
> warning: D:\xxxxx\etc\postinstall\apt.bat no such file
> installing apt 0.3-1
> You might need to manually delete "D:\xxxxx\bin\apt.exe"
> If upgrade is successful it should report "-={ 2015-03.dev }=-" when
> executed.
> cheers,
> Matt
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20150502/7d8f8b6c/attachment.html>
More information about the osgeo4w-dev
