[osgeo4w-dev] Including gvSIG on OSGeo4W
Jürgen E. Fischer
jef at norbit.de
Thu Nov 26 08:49:27 PST 2015
Hi Andrea,
On Thu, 26. Nov 2015 at 17:11:32 +0100, andrea antonello wrote:
> I will jump in as previous uDig and java maintainer for some clarification.
> java is still there because I thought other projects would use it. But
> it is in great shape, i.e. works properly.
Ah, sorry, I didn't know.
> The problem with java is that one xml library of it conflicts with some other
> package and it has been suggested in the past that java would therefore be
> installed as an application.
Right, see also http://trac.osgeo.org/osgeo4w/ticket/441
> That is the problem and should be first discussed. I am not sure who
> makes use of java-gdal bindings in osgeo4w, but several have stated
> that a "general" java might give problems with other packages.
> It might be good to check who still depends on java and evaluate if it
> is better to insert java in the gvSIG installation.
I suppose no one does - neither the (outdated) gdal nor the (uptodate)
mapscript bindings.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20151126/dc5bfa72/attachment-0001.sig>
More information about the osgeo4w-dev
