[osgeo4w-dev] Including gvSIG on OSGeo4W
andrea antonello andrea.antonello at gmail.com
Thu Nov 26 08:57:20 PST 2015
Hi Juergen,
>> The problem with java is that one xml library of it conflicts with some other
>> package and it has been suggested in the past that java would therefore be
>> installed as an application.
> Right, see also http://trac.osgeo.org/osgeo4w/ticket/441
Yes, that is the one I was referring to.
>> That is the problem and should be first discussed. I am not sure who
>> makes use of java-gdal bindings in osgeo4w, but several have stated
>> that a "general" java might give problems with other packages.
>> It might be good to check who still depends on java and evaluate if it
>> is better to insert java in the gvSIG installation.
> I suppose no one does - neither the (outdated) gdal nor the (uptodate)
> mapscript bindings.
Then maybe while I help Cesar to take over, I will also remove java
and add it back as/in the app, so that it stops causing troubles to
the other packages.
Andrea
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
