[osgeo4w-dev] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
trac_osgeo4w at osgeo.org
Mon Dec 12 10:20:54 PST 2016
Reporter: hellik | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: R |
Comment (by hellik):
Replying to [comment:31 hellik]:
> Replying to [comment:30 jef]:
> > Replying to [comment:29 hellik]:
> > > any hints?
> > Access the url using a browser.
> ok thanks, done.
the output of osgeo4w-promote.sh
--- setup.ini.prev 2016-12-12 10:12:31.000000000 -0800
+++ setup.ini 2016-12-12 10:12:31.000000000 -0800
@@ -3,7 +3,7 @@
# See http://cygwin.com/setup.html for details.
arch: x86
-setup-timestamp: 1481530023
+setup-timestamp: 1481566157
@ agg-devel
sdesc: "AGG rendering library (development)"
@@ -2875,6 +2875,12 @@
install: x86/release/qt/qt4/qwt-libs-qt4/qwt-libs-qt4-6.0.2-1.tar.bz2
306829 2a8cbc63a581882b5db9010d1bbecd7e
source: x86/release/qt/qt4/qwt-libs-qt4/qwt-libs-qt4-6.0.2-1-src.tar.bz2
2197 4eae9be815016415611fd0b176443352
+@ rbatch
+sdesc: "Windows batchfiles for use with R"
+ldesc: "Windows batchfiles for use with R"
+category: Libs Commandline_Utilities
+version: r149
@ regex-devel
sdesc: "Regex libaray (source/header) (development)"
ldesc: "Regex libaray (source/header) (development)"
@@ -3,7 +3,7 @@
arch: x86_64
-setup-timestamp: 1481530024
+setup-timestamp: 1481566159
@ alkis-import
sdesc: "norGIS ALKIS Import"
@@ -2141,6 +2141,12 @@
install: x86_64/release/qwt5/qwt5-libs-qt4/qwt5-libs-qt4-5.2.3-1.tar.bz2
261328 4a732090f019931026aa4fe478670ebd
source: x86_64/release/qwt5/qwt5-libs-qt4/qwt5-libs-
qt4-5.2.3-1-src.tar.bz2 3211 5259de566c37bf132c7a60783af575cf
+@ rbatch
+version: r149
@ regex-devel
sdesc: "XDR library (Development)"
ldesc: "XDR library (Development)"
it seems now to be in setup.ini; anything else to do that it is promoted
to be downloadable.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/413#comment:32>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
