[osgeo4w-dev] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
OSGeo4W trac_osgeo4w at osgeo.org
Mon Dec 12 10:34:30 PST 2016
Reporter:  hellik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:  R            |
Comment (by hellik):
 Replying to [comment:32 hellik]:
 > it seems now to be in setup.ini; anything else to do that it is promoted
 to be downloadable.
 http://download.osgeo.org/osgeo4w/x86_64/setup.ini
 @ qwt5-libs-qt4
 sdesc: "Qt4 widgets library for technical applications (runtime)"
 ldesc: "Qt4 widgets library for technical applications (runtime)"
 category: Libs
 requires: shell qt4-libs
 version: 5.2.3-1
 install: x86_64/release/qwt5/qwt5-libs-qt4/qwt5-libs-qt4-5.2.3-1.tar.bz2
 261328 4a732090f019931026aa4fe478670ebd
 source: x86_64/release/qwt5/qwt5-libs-qt4/qwt5-libs-
 qt4-5.2.3-1-src.tar.bz2 3211 5259de566c37bf132c7a60783af575cf
 @ rbatch
 sdesc: "Windows batchfiles for use with R"
 ldesc: "Windows batchfiles for use with R"
 category: Libs Commandline_Utilities
 version: r149
 @ regex-devel
 sdesc: "XDR library (Development)"
 ldesc: "XDR library (Development)"
 category: Libs
 version: 0.12-1
 install: x86_64/release/regex-devel/regex-devel-0.12-1.tar.bz2 31233
 25b7c2a51f7f7d652d27317b696f2bc7
 source: x86_64/release/regex-devel/regex-devel-0.12-1-src.tar.bz2 979
 f8f76c19667fb4303ed87c382eb76fa0
 the entry in setup.ini is now there; but in comparison to the other
 packages the line
 e.g.
 install: x86_64/release/rbatch/r-batchfiles-r149-2.tar.bz2 XYZ
 is missing.
 anything else to do?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/413#comment:33>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
