[osgeo4w-dev] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
trac_osgeo4w at osgeo.org
Thu Jan 7 10:41:13 PST 2016
Reporter: hellik | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: R |
Comment (by hellik):
Replying to [comment:22 jef]:
> Replying to [comment:21 hellik]:
> > > I meant the path added by the ini batch file. It always adds
{{{apps\rbatchfiles}}} to the path - so everything has to search another
path - not only if R being used (or installed).
> > don't understand this. where is {{{apps\rbatchfiles}}} added to the
path?
> $ tar xOjf r-batchfiles-r149.tar.bz2 etc/ini/rbatchfiles.bat
> SET PATH=%PATH%;%OSGEO4W_ROOT%\apps\rbatchfiles
but I've changed that in r-batchfiles-r149-'''2'''.tar.bz2 to
C:\r-batchfiles\etc\ini\rbatchfiles.bat
IF EXIST "%ProgramFiles%\R\" %OSGEO4W_ROOT%\apps\rbatchfiles\R path
in order to avoid this.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/413#comment:23>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
