[osgeo4w-dev] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jan 12 08:19:42 PST 2016
Reporter:  hellik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:  R            |
Comment (by hellik):
 Replying to [comment:23 hellik]:
 > Replying to [comment:22 jef]:
 > > Replying to [comment:21 hellik]:
 > > > > I meant the path added by the ini batch file.  It always adds
 {{{apps\rbatchfiles}}} to the path - so everything has to search another
 path - not only if R being used (or installed).
 > > > don't understand this. where is {{{apps\rbatchfiles}}} added to the
 path?
 > > $ tar xOjf r-batchfiles-r149.tar.bz2 etc/ini/rbatchfiles.bat
 > > SET PATH=%PATH%;%OSGEO4W_ROOT%\apps\rbatchfiles
 > but I've changed that in  r-batchfiles-r149-'''2'''.tar.bz2 to
 > C:\r-batchfiles\etc\ini\rbatchfiles.bat
 > IF EXIST "%ProgramFiles%\R\" %OSGEO4W_ROOT%\apps\rbatchfiles\R path
 > in order to avoid this.
 as the rgrass7 package (R-GRASS interaction) will upcome with a new
 version including improvements for winGRASS-R coupling (see (1)), it would
 be nice to have this in.
 r-batchfiles-r149-2.tar.bz2 doesn't poison unnecessarily %PATH%, it only
 adds R-installation path to %PATH% if R is installed.
 what next to do? I have no access to OSGeo4W repository.
 (1) [http://osgeo-org.1560.x6.nabble.com/Using-GRASS-addons-in-R-on-
 Windows-td5244411.html rgrass7 discussion]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/413#comment:24>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
