[osgeo4w-dev] [osgeo4w] #473: create a geos-c++ package
trac_osgeo4w at osgeo.org
Mon Jan 11 07:40:57 PST 2016
Reporter: rashadkm | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: |
Comment (by jef):
Replying to [comment:4 rashadkm]:
> The question is asked before(on ther mailing list) and answer was and is
"No". Last time, I checked with ossim developers some time ago (1.8.18)
and they said No. "If geos c++ api is no longer available . They will move
to C API"
Fair enough - although I was more looking for something between "yes,
we're using GEOS in a single file and what we need is also in the C API"
and "no, what we need isn't covered by the C-API or we use GEOS C++ all
over the place and could only port with huge effort".
> Q: Why should the package upgrade be blocked because of ossim using geos
c api. ?
I thought OSSIM wasn't using the C++ API!?
> Q: Is using goesc++ api in ossim by any means a violation in osgeo4w ?
How could it? OSGeo4W is a package repository - not a ruleset you can
violate.
> Q: Can you provide a detailed explaination why geos c++ api is not
included while geos-devs says it is supported and is legal to use it. ?
Because using the C++ ABI virtually can break on every update - even if
the compiler isn't switched. You're also tied to using the same compiler
in the dependent package that was used to build the dependency (image
something using Qt (C++) API and GEOS C++ API - if the two dependencies
are built using different compilers - anything using both is screwed).
Using the C API doesn't create that kind of interdependency - that's
probably why the C API is recommended.
And that's probably also why we've put some effort into porting stuff
using C++ APIs to using the C-APIs (GDAL uses GEOS C-API, QGIS uses GEOS C
API and GDAL C-API although they also have C++ APIs). So we didn't need
the GEOS C-API anymore in OSGeo4W.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/473#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
